Vinyl Sheet Flooring & Allure - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 08:37 AM   #1
Rewards Points: 150
Vinyl sheet flooring & allure
I am helping to spruce up a kitchen. The house was built in 1970. It has the original vinyl sheet flooring with a newer vinyl sheet on top. My mom wants the allure planks that look like tile. I think we have to take up the newer vinyl sheet which I think is a bit foamy/squishy. Is 2 layers if vinyl too much to go under the allure? I'm worried with the thickness of the allure the resulting flooring may seem too high although it will be fine meeting up with the carpet at one door and hardwood at the other door.
klmeenan is offline   Reply With Quote
Old 05-04-2011, 08:52 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
http://www.homedepot.com/catalog/pdf...7a22eeeb65.pdf
Can't find anything that tells you not to install over 2 layers of vinyl, but I personally would not. Especially if one is cushioned.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 05-04-2011, 09:19 AM   #3
Rewards Points: 150
When vinyl sheets are put down, do they put the adhesive all over it? I'm just wondering if I can get just one layer off.
Old 05-04-2011, 11:45 AM   #4
Hey Klmeenan,
Allure is made to go over a lot of different types of flooring. It is a completely floating floor. The only reason I wouldn't put it over the two layers of old vinyl is if there are signs of water damage or mold on the subfloor or around the old vinyl. Squishy floors is not a good sign. -Gregg
gotogregg is offline   Reply With Quote
Old 05-04-2011, 01:01 PM   #5
Rewards Points: 56
Originally Posted by gotogregg View Post
Hey Klmeenan,
I think the poster means that at least one layer is cushioned vinyl. And I wouldn't install anything over cushioned vinyl.
Old 05-04-2011, 02:53 PM   #6
Rewards Points: 150
I believe one layer is cushioned vinyl. If it was 2 regular layers I would just put it on.
Old 05-04-2011, 02:56 PM   #7
Rewards Points: 56
It is probably full spread, but it could be looselay or perimeter glued.
Old 05-04-2011, 06:27 PM   #8
Rewards Points: 150
I'm 90% sure it's not loose laid. Do u think if it's only on the perimeter that I can get it up?
Old 05-28-2011, 08:00 AM   #9
Rewards Points: 150
Can't even tell you guys how happy I am that it only has adhesive on the edges. I'm am leaving the lovely 70's stuff. When we put in a real floor we will pay someone to take it up
Old 05-28-2011, 08:03 AM   #10
Rewards Points: 150
Hmm. Along a seam some of the lower level popped up.
Old 05-28-2011, 01:29 PM   #11
Rewards Points: 150
Almost done!
Old 05-28-2011, 01:39 PM   #12
Rewards Points: 56
Looks good.
underlayment materials for vinyl sheet flooring in bathroom eyeglass Flooring 19 01-11-2014 01:14 PM
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 09:50 AM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 04:43 PM
Removing 2 layers of sheet vinyl momof2labs Flooring 5 12-13-2009 01:16 AM
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 10:33 PM
