#1 |
Vinyl self stick over linoleum
Just about done with rebuilding old bathroom. Shiney linoleum still on floor. Can I use self sticking vinyl tile over this? The enhance from Lowes staes not to use over linoleum/vinyl. I wood rather not have to rip it up.
#2 |
Depends, do you want it to stay stuck down?
Peel and stick is one product I flatly refuse to install. It shrinks and leaves open gaps, hard to install straight because of it holding power when it first touches, some places will just not stay stuck down, color does not go all the way through, thin so it will telegraph whatever it's laid over. There's reasons why they suggest not doing it. |
| The Following User Says Thank You to joecaption For This Useful Post: | Bruce99 (03-07-2012) |
#3 |
Pro Flooring Installer
Yes you can. But those peel and stick tiles won't last long, whatever they are put over. They are a temporary floor covering.
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 |
| The Following User Says Thank You to rusty baker For This Useful Post: | Bruce99 (03-07-2012) |
#4 |
Wow. Thanks for the feedback. Thought vinyl self stick was my answer. Therefore the next question is..What would you suggest? Vinyl tiles with adhesive( any different than self stick?), Pergo flooring (? in bathroom), or just get to it and ceramic tile...and if so, can I tile over linoleum?
#5 |
No you can not tile over it and laminite should not be installed in a bathroom.
#6 |
There are only 2 reasonable options in a bathroom, sheet vinyl or ceramic. And to know if you can use ceramic, you have to know subfloor, joists, spacing and species.
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 Last edited by rusty baker; 03-07-2012 at 01:57 PM. |
| Display Modes | |
| Trying to install self stick vinyl tile on ceiling but it doesn't stick | buggy | Tiling, ceramics, marble | 2 | 01-27-2012 06:50 PM |
| Placing vinyl tile over linoleum | phil74501 | Flooring | 5 | 11-11-2010 11:06 PM |
| self stick vinyl tiles over existing linoleum? | cswanson69 | Flooring | 1 | 10-26-2010 01:16 PM |
| Removing Vinyl Tile Adhesive from Linoleum | The Raven | Flooring | 3 | 07-22-2008 09:38 PM |
| Will vinyl tiles stick to this? | rebekkah | Flooring | 1 | 01-12-2008 02:04 AM |
