Vinyl Planks - Need Glue Or Not? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 01:45 AM   #1
Rewards Points: 578
Vinyl planks - need glue or not?
ok we are planning to lay flooring in the bathroom tomorrow so i need fast answers... i have peel and stick vinyl planks. not the floating floor variety, just peel and stick. will these last for at least 5 years without extra adhesive? im going the cheap route now to be able to get moved in, i can update later. do i need extra adhesive or will the peel-n-stick adhesive work for about 5 years?
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 03-24-2013, 07:16 AM   #2
Rewards Points: 14,278
What's the companys web site say or the directions on the box?
Not sure how anyone's going to be able to come up with an ansewer since you did not state what brand it is or at least post it's web site.
In a bathroom I'd be using sheet linolium, so there would be no seams.
It ends up being less expencive and far faster to install.
Old 03-24-2013, 11:45 AM   #3
Rewards Points: 240
what are you putting this on ?
Fix'n it is offline   Reply With Quote
Old 03-25-2013, 01:15 AM   #4
Rewards Points: 578
it went on wood subfloor. and i didnt think that many companies made peel and stick vinyl planks, sorry, its tivoli tile. i dont like linoleum because of the fact that if u get a hole in it you cant repair it
Old 03-25-2013, 07:14 AM   #5
And how do you think your going to fix a hole in one of the glued down strips?
Old 03-25-2013, 08:28 AM   #6
Rewards Points: 578
replace the plank
no glue vinyl floors gfd Flooring 2 01-06-2011 09:25 AM
no glue vinyl floor (armstrong) kirtland Flooring 8 04-30-2007 11:14 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
