Old 07-15-2012, 02:08 PM   #1
Vinyl plank: HD Allure vs. Lowes Armstrong Exquisite
Anyone have an opinion on one over the other? I've read plenty here about Allure but there isn't really much mention of Lowe's equivalent product manufactured by Armstrong.
Both are adhesive strip, floating planks and both have the same warranty (25 year residential). Interestingly, while Allure does not claim to be waterproof, the Armstrong product does.
I will be replacing an existing engineered hardwood floor on an above ground concrete slab in South Florida that shows no signs of any moisture problems. I'm aware of the consensus opinion on Allure and concrete slabs but again, there's really no info on Armstrong Exquisite (or their Luxe plank line) on the forum.
Any input would be much appreciated, thanks....
tobijohn is offline   Reply With Quote
The Following User Says Thank You to tobijohn For This Useful Post:
barrybam1 (07-18-2012)
Old 08-04-2012, 07:09 PM   #2
I would very much to like hear opinions on this as well. I am beginning to look into flooring and am on a very limited budget. I will be installing this myself. I have done the click together floating laminate with good success in small areas.
This floor will be 150 sq. ft and there will be a desk and rolling chair and other office-type furniture on it.
Rainyday is offline   Reply With Quote
Old 08-04-2012, 09:07 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rolling chairs will ruin any vinyl product and void the warranty.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 08-04-2012, 09:16 PM   #4
OK thanks. What if I put a chair pad under the chair?
Do you have any opinions on the two products other than not to use rolling chairs?
Old 08-16-2012, 10:20 PM   #5
I used Allure in my entry way, and it stands up great to the traffic and snow and salt. I would not have a problem having a rolling chair on it. I just bought some Exquisite and it looks just like Allure. I think Allure has a better attachment method it feels more solid. But I like both products. I didn't want any fiber based laminate stuff I just don't trust it when it comes in contact with water.
MyDiy88 is offline   Reply With Quote
Old 08-17-2012, 08:57 AM   #6
Maybe you wouldn't have a problem with a rolling chair, but all vinyl manufacturers say not to use them on their products. I think I would take their advice over yours.
Old 10-05-2012, 11:37 PM   #7
I installed the Allure Planks from HD in two rooms over a year ago and they're still standing. Last week we special-ordered the Armstrong Exquisite brand because we liked one of the designs they had. I just tried installing the first box, and I'm very disappointed by it. The strip where the glue is, is paper-thin and there's only glue on one side of the two parts that stick when you put together the two planks. On a lot of the planks, the sticky strips came bent in different ways because they are so thin, which makes it harder to install. The Allure flooring has a much better sticking method, and is sturdier. Also, after installing the first box of the Armstrong planks, I noticed that the wood-texture layer was peeling off, right out of the box. I'm calling Lowes first thing in the morning to return the product.
tony_hr is offline   Reply With Quote
Old 10-07-2012, 11:38 AM   #8
im a local installer in PA, we have been installing alot of mannington lock solid adura, lock n go. vinyl product, with laminate locking system, no adhesive strips. became very popular here over the past years due to floods, etc.
very durable. with a few tips definitley diy capable.
http://www.mannington.com/Residential/Adura.aspx
i tend to stay away from box store products.
Dantro is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 826 02-05-2013 03:47 PM
Allure Ultra/Traffic Master Lock and Click Vinyl Plank Scott Nei Flooring 0 04-20-2012 08:36 AM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
