Vinyl Plank Flooring - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 01-04-2017, 11:28 AM   #16
CurtisE's Avatar
Question
Re: Vinyl plank flooring
Originally Posted by rjniles View Post
The clip together has camfering on the long edges and the ends. Makes it look more like a natural product. The glue strip lies very flat with no definition between the pieces.
The glue strip do not leave gaps if you lay it carefully. But if you are sloppy, there is no moving it once it sticks.
Isn't the so called "click together" type considerably thicker than the "glue type"? That is my understanding, and was the case for me. I have both types in my house. The allure Ultra wasn't available when we installed the original Allure. It is thinner and shows most every irregularity of the underfloor (in our case, concrete).
CurtisE is offline   Reply With Quote
Old 01-05-2017, 10:39 AM   #17
Rewards Points: 3,520
Just went back and looked at mine, it's not the Ultra, it's the original Allure, and it's 4mm thick which is the thickness of two nickles, and nothing telegraphs through it.
Canarywood1 is online now   Reply With Quote
Old 01-05-2017, 12:07 PM   #18
CurtisE's Avatar
The regular Allure is:
  • 3.8 mm thickness x 6 in. width x 36 in. length
  • 4 mil wear layer offers protection against damage
The Allure Ultra is:
  • 5 mm thickness x 7.5 in. width x 47.6 in. length
  • 20 mil commercial-grade wear layer with a ceramic bead overlay
Maybe your floor is smoother than ours? The regular Allure planks show pretty much every flaw of our floor when you view with the right angle. Still looks good though.
Applying vinyl plank flooring on top of uneven concrete floor techpappy Flooring 4 03-29-2016 02:38 PM
Vinyl plank is cupping-seller says put down plastic akimbo Flooring 3 02-04-2012 10:37 PM
Laminant vs vinyl plank flooring gin and ger Flooring 2 01-27-2012 11:31 AM
vinyl plank flooring dspottenger Flooring 4 07-29-2011 10:35 PM
? vinyl plank flooring markhelton Flooring 1 12-13-2010 10:35 PM
