Old 07-18-2011, 06:36 PM   #1
vinyl plank flooring
which should I install? Allure vinyl with adhesive strips, Allure Ultra that snaps together or Armstrong Luxe vinyl planking with adhesive strips? Which is most waterproof for pet accidents?
dspottenger is offline   Reply With Quote
Old 07-19-2011, 08:58 PM   #2
If you search for allure or allure ultra you will find plenty of information on them to decide if you want to use them or not.
klmeenan is offline   Reply With Quote
Old 07-19-2011, 09:11 PM   #3
to use allure your subfloor needs to be very flat
kt82 is offline   Reply With Quote
Old 07-29-2011, 11:17 PM   #4
I only know about the Allure products. But after trying to get the click to stay on the new Allure Ultra, it probably will be easier for you to stick with the Allure with the grip-strip. It's less expensive anyway and has more of a selection.
ttr13r is offline   Reply With Quote
Old 07-29-2011, 11:35 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Why not use a sheet vinyl like Flexitec? No gaps to collect urine and easier to install than planks.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
?laminate or allure vinyl plank flooring? suevwbug Flooring 0 05-09-2011 10:26 PM
Which vinyl plank flooring to buy? CowardlyDIYer Flooring 2 04-10-2011 09:45 PM
Installing vinyl plank flooring stevensmr61 Flooring 2 01-23-2011 12:57 PM
? vinyl plank flooring markhelton Flooring 1 12-13-2010 11:35 PM
vinyl plank flooring? annie68164 Flooring 1 08-18-2008 01:10 AM
