Vinyl Plank Is Cupping-seller Says Put Down Plastic - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 09:49 PM   #1
Rewards Points: 101
Vinyl plank is cupping-seller says put down plastic
I won't mention the brand name, but we installed one of those new plank vinyl floors that do not require gluing. "Simple to install" which it wasn't but we followed the directions carefully and the floor was very snug, i.e. no gaps between planks. The company advised us to use double-sided tape on some of the short ends which we did.
We have a nice smooth basement floor from which we removed an old vinyl floor.
Because of some concerns about possible asbestos in the old glue we sealed the concrete, prior to install of new floor, using concrete sealer--the kind that goes on milky and dries clear. At least 2 coats were applied.
Six months after installing the vinyl planks we noticed some of them were cupped, forming a potential tripping hazard so we applied more double sided tape.
A year later when the cupping progressed we called the company. They came for an inspection and found some moldy areas under some planks. This was surprising as we had done repairs to our drainage and foundation two years previous, plus we had sealed the concrete. Furthermore when removing a two year old carpet in an adjacent room, there was no evidence of mould or moisture.
The vinyl flooring was advertised as appropriate for concrete basement floors. A company rep is now advising us to remove the flooring, put down 6 mil poly over the concrete and to reinstall the planks. I'm reluctant to do that because with even a millimeter of play the flooring is going to cause the planks to slide in this rental unit. And I wondering about creating an even better environment for mold under the plastic. I even wonder if the planks are promoting the growth of mold. Any thoughts?
akimbo is offline   Reply With Quote
Old 01-29-2012, 05:28 AM   #2
DIY staff
Rewards Points: 7,174
Please go ahead and mention the Brand and style---
If this is what I think--there is a long running thread on the product---along with some fixes.
Old 01-29-2012, 02:45 PM   #3
Rewards Points: 101
The product is Drop & Done.
Old 02-04-2012, 10:37 PM   #4
Rewards Points: 101
I see the company has changed the info on their web site now. There is a warranty but the company is not being as helpful as when I first contacted them.
Swiftlock VINYL plank flooring keithl1967 Flooring 21 06-11-2013 06:34 PM
Plastic 4mil under interior walls? Avadon Carpentry 4 05-03-2011 06:36 PM
Which vinyl plank flooring to buy? CowardlyDIYer Flooring 2 04-10-2011 08:45 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
