Vinyl Over Vinyl (flooring) - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 05:25 AM   #1
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
vinyl over vinyl (flooring)
vinyl over vinyl?
Hey guys, I am a paper hanger, painter by trade but my wife wants a new floor in the basement and I have a question or two. The existing floor is 9 by 9 inch tile(old from the 40's, I would guess, so no doubt asbestos)I did the laundry room area by removing the old tile which came up fairly easily( except for the black glue) and replaced with ceramic, but it is kind of thick and would be expensive to replace the entire basement with. I was wondering about the self stick tile I saw at Blows. Could I just put this on top of the existing or as with wallpaper is it better to remove to old tile? Would regular tile be better?I know the floor has to be almost perfectly smooth for tile as I did my kitchen and ANY piece of crud shows through, that is why I was thinking about going over the existing. Also, just to add , this room CAN get flooded ,it has only happened once in 25 years but I am thinking that this would eliminate ANY type wood product. Any ideas or tips are welcome, thanks.
Chris
Old 02-18-2008, 05:52 AM   #2
Guest
Guest
Posts: n/a
I'd suggest a fiberfloor like IVC. It's a soft back sheet vinyl. Made from a Fiberglass core. You can loose lay it though I recommend a full glue. If it's vinyl tile you have down now, some minor patching may be in order but the IVC will glue right over it. Best part is this stuff is virtually impervious to water. I've seen a place get flooded with it and they just pull it out, let it dry and reinstall it.
Old 02-19-2008, 06:14 AM   #3
chrisn's Avatar
Rewards Points: 474
Thanks.
Vinyl flooring on stairs, need input mgarfield Flooring 6 01-29-2008 10:04 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
