Vinyl Over Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 07:47 PM   #1
vinyl over vinyl flooring
My house was built in 1995. Lowes told me they have a policy against removing vinyl flooring. If i did new vinyl on top of the current, how much will the floor height increase? will it be enough for me to worry about the DW being locked in?
ri98 is offline   Reply With Quote
Old 11-08-2011, 08:15 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
You need 1/4" plywood underlayment and then the thickness of the vinyl. Don't know why they won't take up the old, most stores will. 1995 vinyl should not have asbestos.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ri98 (11-08-2011)
Old 11-08-2011, 08:28 PM   #3
Thanks. Do i need the underlayment even if they are putting on top the current vinyl? The store said something about putting some glue.
Old 11-08-2011, 09:00 PM   #4
Rewards Points: 42
The pattern from the bottom vinyl will telegraph thru the top one.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-27-2011 12:13 AM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
