Old 03-06-2011, 05:15 PM   #1
Vinyl over old linoleum
Bow would I go about laying a vinyl floor over very old linoleum? There are some spots where it is worn/rotted a bit. I guess a subfloor needs to be laid first. It's a small area, perfectly rectangle, so it should be pretty straight forward. Would I just put down 3/4" plywood or special type subfloor material? Then does the vinyl adhesive go right over that?
124sport is offline   Reply With Quote
Old 03-06-2011, 05:22 PM   #2
Coatings Nerd
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-06-2011, 05:39 PM   #3
...because this is just a temporary fix as my 86+ year old folks are probably not gonna be in this house much longer. House will probably be gutted and remodeled in the not to distant future. That's why.
Old 03-06-2011, 06:20 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Use floor patch on the bad spots. Install an IVC back vinyl like Flexitec over the top of the lino.
http://vinylflooring.org/movie.html
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 03-06-2011, 06:29 PM   #5
Coatings Nerd
Old 03-06-2011, 07:38 PM   #6
Ok. Sorry for the smartass comment. The subfloor isnt necessarily rotted..,just the linoleum. Pretty sure the subfloor underneath is solid. Frankly, it probably could be just leveled/patched as suggested above. And...it won't be me or any of my siblings gutting/remodeling this house when they move on...so won't be doing it twice. Honestly, any rehabber would probably rip this little (formerly a porch) attached room off and rebuild it.
The Following User Says Thank You to 124sport For This Useful Post:
oh'mike (03-06-2011)
Placing vinyl tile over linoleum phil74501 Flooring 5 11-11-2010 11:06 PM
self stick vinyl tiles over existing linoleum? cswanson69 Flooring 1 10-26-2010 01:16 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
