Vinyl Flooring With Or Without Luan? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 08:01 PM   #16
Originally Posted by Live_Oak
Luan is crap or just about anything. It's the seal of certain disappointment for a flooring underlayment. If your budget is limited, why not do they plywood, seal it, and then DIY some type of snap together vinyl plank. You could do a little bit at a time and save all of the labor costs.
It's something to consider. I thought though that sheet vinyl would be less expensive.
csmallich is offline   Reply With Quote
Old 12-04-2013, 08:19 PM   #17
747
registered
747's Avatar
Rewards Points: 534
I just had my dinning room living room and hallway recarpted. I also had sheet vinyl laid in entryway. I asked lowes to stop by. 50 dollar and the guy was a dickhead. I then went to FCA completely different ballgame. Walked in on Saturday. Women showed up next day Sunday morning. Went with them 2800 dollars. The installers did a great job. Unfortunately i left when they were messing around with entry way so i didn't see how it was handled. But it turned out great. Took 3 guys 9-3:45pm. Bottom line . Don't go with Blowes. Go with a store which only does flooring. Sheetvinyl is an excellent choice for kitchen. Just don't cheap out.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
rusty baker (12-04-2013)
Old 12-04-2013, 08:36 PM   #18
Rewards Points: 197
If you decide on a vinyl product you want to use it's easy enough to Google the manufacturer and product name to find the installation instructions. They will certainly tell you exactly what underlayment you are supposed to use. Never ever trust anything a clerk at Home Depot or Lowes tells you until you verify it on your own.
Arlo is offline   Reply With Quote
The Following User Says Thank You to Arlo For This Useful Post:
csmallich (12-04-2013)
Old 12-04-2013, 08:43 PM   #19
Registered User
Rewards Points: 5,460
In this "information age" do some research. Here is a 13 year old paper on underlayments, just Google "lauan"; http://bct.eco.umass.edu/publication...ient-flooring/
And the install; http://www.google.com/url?sa=t&rct=j...KEftFQ&cad=rja
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 12-04-2013, 11:27 PM   #20
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
From that article
"APA’s installation guidelines for 1/4-inch plywood should be followed when installing lauan plywood, but installers BEWARE: Lauan is made under a wall-panel specification of the International Hardwood Products Association (IHPA). No manufacturing specifications support its use or gauge its performance as an underlayment. - See more at: http://bct.eco.umass.edu/publications/by-title/wood-underlayments-for-resilient-flooring/#sthash.ef4wuIIW.dpuf"
And I can tell you as someone who has installed resilient flooring since the 70s, the luan you see today is far poorer quality than it was just a few years ago.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-21-2013, 07:45 PM   #21
Rewards Points: 82
And by the way, interflex vinyl is a discontinued product. It is no longer made because of all the problems.
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-04-2012 11:09 PM
patching holes in vinyl flooring with formica repair kit h82diet Flooring 1 12-02-2011 10:18 PM
Sump pit under vinyl flooring Wheats Plumbing 4 11-20-2010 06:38 AM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 10:50 PM
Opinions on armstrong no-glue vinyl flooring thebestman36 Flooring 5 11-05-2008 05:18 PM
