Vinyl Flooring Onto Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 07:27 AM   #1
Vinyl flooring onto concrete
Hi folks. Found your site through Google. Need some advice.
Am attempting to vinyl a roll of wood effect in my hallway- by the front door.
Am intermediate when it comes to DIY. The concrete floors were not finished so well- courtesy of the dodgey developers... its a bit like the house that Jack built.
I had a quote off a firm who said i would need to stick wood down before laying the vinyl and fixing it to the wood. Which i spent all day measuring out and cutting the Ply... i haven't fixed the ply yet as i read your comments re not a good idea... waste of time cause the wood and concrete wont work together with moisture. All valid and (in my case) worthwhile advice
So- really i just need confirmation... its better for me to just cut the vinyl to size and fix with adhesive straight onto the concrete?
Do i need to do anything to the concrete first? (apart from get off all the noggins and fill the corner that's collapsed - which case would polyfiller do the trick?)
Cheers in advance folks. Your opinions and expertise is valuable to me
Thanking you in advance
PaulaT.UK71
paulaT.71UK is offline   Reply With Quote
Old 05-17-2012, 07:44 AM   #2
DIY staff
Rewards Points: 7,174
If the concrete is wavy and uneven, consider using a self leveling compound--this is a cement like powder--mixed with water or liquid latex--(old concrete must be primed if mixed with water)
The mixed product is poured on the floor--quickly and gently leveled out with a trowel--then left to float out flat---
the stuff sets up very fast,so don't waste time--
I don't know what brands you have available in the U.K.---Mike---
Tags
advice re vinyl flooring , jaz
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 07:46 AM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 04:47 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 02:16 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
