Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 04:17 PM   #1
vinyl flooring
I'VE BEEN TOLD YOU CAN'T LAY LAMINATE FLOORING OVER A CEMENT FLOOR DUE TO A HIGH MOISTURE CONTENT. DOES THAT ALSO GO FOR A VINYL FLOORING LIKE FLEXITEC?
THANKS
JAN
petersonjan850 is offline   Reply With Quote
Old 05-15-2010, 09:41 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You can lay either one on concrete if you follow the installation guidelines correctly.
poppameth is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Ripping up Vinyl Flooring harmony Flooring 5 02-26-2008 04:50 PM
vinyl over vinyl (flooring) chrisn Flooring 2 02-19-2008 06:14 AM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
