Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 10:59 AM   #1
Rewards Points: 12
Vinyl Flooring
How clean does the subfloor need to be before i glue down the vinyl? Part of the floor is old plywood and still has glue residue from the old vinyl. Also how do i know where i should put glue down on the entire floor or just the perimeter?
jseymour186 is offline   Reply With Quote
Old 08-19-2011, 12:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
The floor needs to clean and smooth. Any imperfections will show through. Full spread or perimeter glue, depends on the vinyl.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-19-2011, 02:50 PM   #3
Rewards Points: 12
Do you have any recommendations for cleaners for removing any glue residue?
Old 08-19-2011, 04:04 PM   #4
Rewards Points: 42
It needs to be scraped. Chemical cleaners can keep the new adhesive from sticking.
Old 08-19-2011, 06:08 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The old floor can be overlaid with new 1/4" underlayment. Typically that is how it is done.
XXX
Old 08-20-2011, 01:41 AM   #6
Rewards Points: 12
can i use joint compound to fill cracks and screw holes in the sublfloor?
Old 08-20-2011, 09:29 AM   #7
Rewards Points: 42
NO! It needs to be a cementious based fill. Joint compound will not hold up. And if you put down a new 1/4" underlayment, do not use screws. They will cause it to pucker. Use 9/16" 18 ga staples.
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 05:04 PM
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
