Vinyl Floor Tile Adhesive Residue Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 05:33 PM   #1
Rewards Points: 107
vinyl floor tile adhesive residue removal
I have a cement floor with slate tile on it, someone put stick on vinyl tiles on the slate. I pulled the vinyl tiles up today and the floor is so sticky that I pulled a shoe off while walking on it. I don't care about the slate, I am going to put vinyl tiles back over it anyway, but I have to get that glue off. I tried wetting it down good and scraping. I was able to get a little of it up but it is so gummy it will take forever. Any ideas of the best adhesive removers so this doesn't take me forever to get done? TIA
thunderhead is offline   Reply With Quote
Old 12-04-2011, 06:21 PM   #2
DIY staff
Rewards Points: 7,174
Both of these are flammable so you could blow yourself up if you are careless---
Mineral spirits---and xylene---These will work--But shut off the pilot lights on your water heater ,furnace and stove if you are any where close to them----
Old 12-04-2011, 06:58 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Shoul have allowed it to remain and used it to enhance the bond of your new vinyl tile installation.
XXX
Old 12-04-2011, 10:11 PM   #4
Rewards Points: 107
Thanks for the replies, I will try the mineral spirits. I thought about leaving the glue on but it was so sticky I couldn't move the tiles if I got them on wrong.
Old 12-05-2011, 10:31 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How's that going to change?
XXX
Old 12-05-2011, 10:47 AM   #6
Rewards Points: 107
This is thick glue, I suspect maybe someone used extra glue on these. I can slide a tile a little if I start by putting just a small corner or end down. Not on this stuff though.
Moisture Barrier and Adhesive Removal joe_cole5000 Flooring 5 01-31-2010 03:06 PM
Vinyl Floor Adhesive Bruiser Flooring 1 05-06-2009 06:28 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Adhesive Removal SIE Flooring 4 07-05-2005 10:50 AM
