Vinyl Floor Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 03-17-2006, 03:20 PM   #1
Question
vinyl Floor Removal
"Hello you floor experts out there",
I am removing two layers of vinyl flooring in my bathroom. Both floors are self adhesive vinyl tiles and i am having a devil of a time removing them.
I heard that if i put heat to the tiles they would be easier to remove. Is this true?
If not, then what can i do to make this process easier?
king45 is offline   Reply With Quote
Old 03-17-2006, 05:15 PM   #2
Contractor
tgeb's Avatar
Heat will help. Try a hair dryer, see if it works. Then I would use a heat gun if available to you.
Better yet if this is put down over luan or 1/4 inch ply, get under that and it could come up in sheets.
Tom
Tom
www.gebcon.com
tgeb is offline   Reply With Quote
Old 03-20-2006, 12:48 AM   #3
Talking
Thanks Tom,
I appreciate that advice. I used a blow torch and it worked out great. :D
Old 03-20-2006, 08:42 PM   #4
Contractor
tgeb's Avatar
Blow torch is heat. Glad it worked out.
Tom
Tom
www.gebcon.com
glueless Vinyl product NoviceDIY Flooring 7 08-20-2010 05:52 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Vinyl siding brickmold rjniles Building & Construction 1 02-05-2007 10:55 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
