Vinyl On Cocrete.. Moisture Issues? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 10:32 AM   #1
Vinyl on cocrete.. Moisture issues?
Just ripped up the carpet and pad in the walkout basement of oir new house. It has very old vinyl type sheet flooring. I would assume it has asbestos but havent tested it.
I want to lay carpet and pad down. How does the old glued down sheet flooring effect the moisture that may rise up through the floor? Does it have a perm rating? There are some dark spots on the old floor, not sure if its mold or just from the adhesive. The old flooring is mostly intact, no bubbling etc...
Is it safe to just carpet over the old stuff?
Maine1 is offline   Reply With Quote
Old 12-18-2012, 11:16 AM   #2
Rewards Points: 13,444
Try hitting the stains with some bleach and water to see it it goes away.
Could be as simple as someone used the wrong glue and the color bled through.
The mold should have shown up on the back side of the old pad.
Ever check the moisture level in the room?
Old 12-18-2012, 11:29 AM   #3
I plan on scrubbing it down with TSP. One of the rooms (there are 2 bedrooms and a bathroom) has some moisture issues from the wall that I will repair.
I just wanted to make sure it was okay to place the carpet and pad over the existing flooring.
Thanks for the help!
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 12:31 AM
Prying carpet tackboard out of asbestos vinyl ... safety issues? jacoite Flooring 5 09-13-2009 10:29 AM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
