Vinyl To Carpet Transition On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 09:11 PM   #1
Vinyl to Carpet Transition on concrete
I have a few questions regarding vinyl to carpet transition on concrete.
First, I've read topics that suggest using PL400 or something similar to glue the transition down. I couldn't decipher whether that meant to glue the wood piece itself, or to glue the metal channel that the wood piece snaps into? Those are the only T moldings I am familiar with anyways. (the ones with the channel).
2nd, my transition piece is 13'6" wide and I can't find a piece that large. Do I have other options besides splicing 2 pieces together? I found a 12' T-molding piece but that is as big as I've seen so far.
I've attached 2 pieces of the area, the vinyl is not installed yet. Thanks in advance for any help or suggestions.
ds28 is offline   Reply With Quote
Old 04-21-2013, 09:59 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
Transitions are only made 12' long. I normally nail them down with concrete nails.
sam floor is offline   Reply With Quote
Old 04-23-2013, 09:57 AM   #3
any other suggestions? nail the channel? put a 12 footer in there with a 1.5' piece spliced onto it?
Old 04-23-2013, 10:45 AM   #4
Floor Installer
sam floor's Avatar
Rewards Points: 154
That's how it's done or use naplock.
Old 04-23-2013, 10:46 AM   #5
Floor Installer
sam floor's Avatar
Rewards Points: 154
That carpet will wrinkle, not being stretched in.
Old 04-25-2013, 06:34 AM   #6
Floor Installer
sam floor's Avatar
Rewards Points: 154
He would still need a transition between the two. But clever attempt to sneak in some spam.
Old 04-25-2013, 12:44 PM   #7
Not a carpet guy but i do know the carpet does need to be streched. Install vinyl then overlap carpet and install a j-bar (think that is what they are called).
skipoff is offline   Reply With Quote
Grinding concrete to remove carpet glue, and matching height of existing laminate... dmh0284 Flooring 12 04-22-2015 04:51 PM
transition from vinyl laminate flooring into carpet dajustice Tiling, ceramics, marble 1 02-12-2013 03:10 PM
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 11:42 AM
Self Stick Vinyl Plank on Painted Concrete ChrisWorth Flooring 6 01-18-2012 08:58 AM
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 10:21 AM
