Old 08-31-2008, 04:56 PM   #1
Very bumpy concrete floor that is not level
I have read through all the posts asking for advise on leveling floors/building subfloors/laying tile/etc on uneven floors. I really can't find anything that helps me with my specific problem.
I have a detached garage/workshop that I want to make a family room out of. The room is approx 15' x 25' and has a horrible concrete slab underneath it (25' length goes east and west). The floor slopes from the northeast corner to the southwest corner with approx a 5" drop. I realize this was probably done for drainage for this workshop, but I would like to carpet/tile/whatever the floors to make the room family friendly and warm in the winter. The concrete is also horribly bumpy (high and low spots - to create an uneven slope to the southwest). I live in a very dry area in Colorado and really do not need to worry too much about moisture. Most garages in my area are setup without a concrete foundation.
Options:
1-Pour a ton of self leveling concrete (in sections)to raise up the soutwest corner of the garage floor, even with the northeast corner of the floor.
2-Calculate the amount of cement needed and buy (appx 1+ yards) concrete and attempt to level all at once.
3-Build a wooden subfloor on top of the sloped/warped concrete to attempt to level the surface.
4-Separate the room and make two levels (est and west half), due to the huge slope/drop in concrete. Using self leveling concrete to make minimal adjustments...
5-Demo garage and build a new one over a new concrete slab (not cost effective)
6-Any other suggestion????
My main goal is to spend as little as I can so I can make a room that we can hang out in for movies, games, etc.
PLEASE HELP!!
Your ideas could save me hundred or even thousands of dollars!!!!!
Thanks!
cgcaudle is offline   Reply With Quote
Old 08-31-2008, 05:04 PM   #2
Tileguy
#5
OK OK OK, you could use regular low cost cement to raise and fill the low side to a point that it could be capped with a minimum of Self Levelling Compound.
Once the repairs are in range, SLC could be flooded over the entire area to creat a nice new seamless flat floor surface you could do anything you want to with.
More On This Topic
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through the procedure for cleaning out our room. The room that we are converting into a baby room is currently used as a part storage room and part office. Our first step... Read More »
Jumping Rope on a Mat
Jumping Rope on a Mat by Expert Village
The next area we want to look at is, we're going to call the jump rope mat. Ideally, through the actual design of jump roping, you're putting a lot of torque on those lower muscles in your legs but also the bones in your feet and stuff. So you want to be... Read More »
Whether you have one dog or several, a place in your home that is exclusively a dog space can prove convenient and practical. A dog room offers play space, kenneling during the work day or at night and an indoor kennel when house activities are not dog... Read More »
How to Store Hay
How to Store Hay by eHow.com
Hay is a necessary items in those parts of the country that do not have the benefit of temperate weather all year round. Hay, when stored properly, can feed your horses and cows nutritious food even in the dead of winter. Storing your hay properly is... Read More »
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
How to level small patch of cured concrete? RDS General Discussion 11 06-05-2008 01:41 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Concrete Deck Footings Bumpy Melanie337 Building & Construction 6 09-24-2007 09:11 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
