Vertical Tile On Wall - Flooring - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 09:01 AM   #1
Rewards Points: 129
Vertical tile on wall
As a DIY'er, I've tiled several floors. However, I am now getting ready to tackle something that I haven't done before....vertical tile as a backsplash around a garden tub. I've already layed the tile around the tub. Before I get started with the vertical wall tile, I have several questions...
I am using 6.5 x 6.5 porcelain tile with 1/8" grout lines. I am going two rows high and then a 3 x 12 bullnose. The substrate is green board
1. Should I have a space where the vertical tile makes contact with horizontal tile? If so, how much space?
2. I have two corners where vertical tile will meet. Should there also be a space left there?
3. Should I use a special thinset (fast setting)? I used Mapei Type 1 Tile
adhesive on the horizontal tile. (note: I liked working with this adhesive, but it DID NOT set up very quickly....about 36 hours)
4. Should I butter the back of each tile or should I try to spread a bed on the wall?
Any other general tips or recommendations on tiling on the wall?
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 06-01-2010, 09:38 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Hi Chris,
I find most tiles installed to walls are indeed vertical.
1. Yes, 1/8" is fine. Caulk it.
2. Yes, 1/8" is fine. Caulk it.
3. Mastic on this wall will be good enough cuz it's not a wet wall installation. What is the substrate of the deck? Thin set mortar would have been a much better choice for the deck. If the mastic gets wet it'll re emulsify like when it was in the can.
4. Spread with proper notched trowel on the wall is best. You can butter the backs, but shouldn't have to. Check for adhesive transfer after you set a few.
Was there a shower installation involved in this project?
Jaz
Old 06-01-2010, 10:05 AM   #3
Rewards Points: 129
Jazz-
Thanks for the info. I should have done a little more research on the mastic, but you live and you learn! It should be ok, an splash here and there shouldn't hurt the mastic.
No, there isn't a shower stall in this project.....maybe as a phase 2.
Thanks again.
Originally Posted by JazMan View Post
Hi Chris,
Jaz
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
French drain tile exterior wall lsaucy Building & Construction 4 05-30-2010 04:22 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 01:57 PM
