VersaBond Vs. FlexBond - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 08:07 PM   #1
VersaBond vs. FlexBond
i've done as much reading as i can and decided to just ask people who know what they are talking about.
i'm intalling 12x24 porcelain tile in my entry (approx 82 square feet total). sub floor is all set and i will be using 1/4 hardie backer.
my question is on which mortar to use. flexbond seems like the best, but i've heard its harder to work with and costs more than versabond. to save a few bucks, can i use versabond under the hardie backer and flexbond under the tile? thanks!
mklang is offline   Reply With Quote
Old 12-08-2010, 10:01 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
Yea you can do that, (use two) to save $15 or so. You can even blend a little Versa with the Flexbond since you won't need the entire #50 to set the Hardie and you may be a bit short to set the tiles. What size notched trowel will you be using?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
mklang (12-09-2010)
Old 12-09-2010, 11:44 PM   #3
hardie backer website says to use a 1/4 by 1/4 trowel for the mortar between the hb and the subfloor. i was planning on doing that, and using a 1/2 by 1/2 for the tile. sound right?
Old 12-10-2010, 08:19 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
Sounds perfect!
Be sure to mix the batch for the HD a bit thinner than normal. Don't forget the mesh tape.
Jaz
Old 12-11-2010, 07:51 AM   #5
thanks JazMan!
Old 12-13-2010, 09:54 AM   #6
one more question... is fiberglass drywall tape the same as the tape used for hardie backer? also, does the tape/mortar need to dry before i go ahead and lay the tile?
thanks!
Old 12-13-2010, 03:03 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 340
It probably is the same, but there are some who think it is not, I'm not sure. I used the fiberglass tape found near the drywall tools for many years when I used to use concrete board and never found a problem. Some people say to use the tape made especially for concrete board since it has to be alkaline resistant because of the thinset. Well, drywall compound is highly alkaline too.
I usually taped and let it dry for a while or overnight. It all depends on the job and how much time is left before you stop. Some people like to tape as they go because they had problems with creating speed-bumps on the seams. I never had that problem and whenever I tried taping and setting right away, the trowel would pull the tape off and make a mess. Either way is fine. You should use a 6" flex putty knife for best results.
Jaz
Old 12-13-2010, 03:23 PM   #8
cement board tape feels thicker in the strands. harder to bend and a bit heavier. i agree they could be interchangeable though. i actually did a small drywall patch last night with cement board tape
racebum is offline   Reply With Quote
