VCT On Subfloor, Need Backer Board? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 02:17 PM   #1
Rewards Points: 16
VCT on subfloor, need backer board?
Hi all,
I'm about to install VCT in a closet. The sub-floor needs some patching due to marks from carpet strips and a few places where the sub-floor panels don't quite meet evenly anymore. I'm thinking about just sanding off the paint (someone at some point painted the sub-floor) and using a self leveler/patching compound and then putting the VCT down on that. However I've also read that backer board might still be a good idea. If so should I lay the backer board directly on the sub-floor or should i put down a layer of thin set first (which hardiboard, for example, says you should do for porcelain tile but doesn't seem to suggest that for VCT). Guidance would be greatly appreciated.
Thanks!
Melissa
mantissa is offline   Reply With Quote
Old 09-30-2012, 07:34 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
You don't use backer board or thinset for VCT. You do need a smooth floor and you use clearset adhesive.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
mantissa (09-30-2012)
Old 09-30-2012, 08:50 PM   #3
Rewards Points: 16
Thank you Rusty. That's what I thought but I read conflicting info on putting down thinset, then backer board and then the adhesive - which seemed excessive to me. I'll just get the subfloor smooth and put down my VCT.
Thanks!
Melissa
Old 09-30-2012, 09:17 PM   #4
Rewards Points: 124
Make sure that you follow the instructions on the adhesive. It must dry before the tile is installed and you must use the proper trowel.
Old 09-30-2012, 09:17 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
Mellissa,
NO, that is not the right way to do it. But, it's only a closet and so if the height works out ok and the floor is otherwise firm, go ahead and skip a step. Don't be surprised if the seams telescope through to the tiles and the tiles eventually crack.
Otherwise........ You do not install VCT on a subfloor, you need and underlayment such as 1/4" AC ply or something made for vinyl floors.
So, firm up the subfloor with screws as necessary, then install 1/4" underlayment, then the vinyl tiles.
Jaz
Old 09-30-2012, 09:21 PM   #6
Rewards Points: 124
In a closet, I would not worry about underlayment. Laying it on a plywood subfloor with patched seams should be fine.
Old 10-01-2012, 06:32 PM   #7
Rewards Points: 16
Thank you both for your advice! If I do install an underlayment can the subfloor be a little uneven or should it first be smoothed out with a leveler? It's not much of a dip but there is a bit when you check it w/ a straight edge.
Old 10-01-2012, 06:40 PM   #8
Rewards Points: 124
If you are going to put down an underlayment, might as well even the floor out first.
Old 10-01-2012, 07:33 PM   #9
Rewards Points: 16
Good point. However someone painted the subfloor. Have you had any issues/experience with leveling compounds having problems not adhering to paint? If so then I'd still need to strip off the paint and I'm trying to find a way around that unless I have to
Old 10-01-2012, 07:40 PM   #10
Rewards Points: 124
Don't think you'll have a problem as long as the paint is well adhered.
mantissa (10-01-2012)
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 01:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 06:36 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 01:30 PM
