VCT Not Completely Set - Help On Possible Reasons Why? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 07:17 PM   #1
Rewards Points: 16
VCT not completely set - help on possible reasons why?
I put VCT in a large closet I have. Before I put it down I put down a new plywood underlayment. I used Roberts 2057 adhesive with armstrong tile - used the recommended trowel size and let it dry clear. After all was put in I used a rented 100lb roller and let it set for a few days before walking on it. It's still empty so theirs no weight on it now.
Now about a month and a half later I was in the closet with a ladder to get in the attic and the pressure from the ladder moved the edge pieces. Upon investigation I found they are sliding out of place with enough side pressure. I have no idea why they haven't set as I followed the instructions I've found to a t. Any suggestions/advice as to what could cause this?
Thanks!
mantissa is offline   Reply With Quote
Old 05-04-2013, 09:07 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
You let the adhesive dry completely before you installed the tile?
sam floor is offline   Reply With Quote
Old 05-04-2013, 10:07 PM   #3
Rewards Points: 16
Yes. I troweled it on and waited till it turned clear. It was tacky to the touch but dry I believe.
Old 05-04-2013, 10:43 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 288
Those type of vinyl tiles with that kind of adhesive need traffic to stick better. They stick by making contact. Of course the edge tiles rarely get walked on, so they don't bond as well. Still after a while their own weight should be enough to get a good bond.
Possible reasons; The floor may not be flat and the tiles aren't touching the adhesive, the floor is too cold, the tiles laid too tight. Sometimes they take several weeks or longer to flex into the adhesive.
Jaz
Old 05-05-2013, 08:26 AM   #5
Remodeling Contractor
These were dry back Armstrong tiles, Right? Probably 1/8"?
They do like to be warm to lay down. Sure that you don't have any
moisture issues?
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
Old 05-06-2013, 01:00 PM   #6
Rewards Points: 16
Thank you Jaz for the list of possible reasons. The floor is definitly flat so that's not it and I'm in Texas so cold is definitely note an issue. However being in a closet they aren't getting much weight so that's on the list.
Correct pgc555 - dry back Armstrong. It was warmish when they went in - maybe around 60 or 70 F. I don't believe I have moisture issues - dry closet, no pipes. Can you give me pointers on what to be looking for in regard to possible moisture issues? The floor is over a crawl space so would moisture include humidity (which we do have in Texas)? It can get pretty hot in humid in the crawl space.
Thank you all for your help.
PEX now completely respectable? darsunt Plumbing 28 07-07-2011 03:50 PM
Any reasons I should NOT build the deck before the door? CoconutPete Building & Construction 34 07-21-2010 04:50 PM
Vessel sink doesn't drain completely Lin Plumbing 3 04-25-2008 12:35 AM
four important reasons wood-butcher Carpentry 2 10-09-2006 07:08 AM
