Old 07-08-2012, 01:49 PM   #1
VCT adhesive
I have about 80sq ft to cover in an attached storage space. The slab is old and a little uneven and has some stains that may be oily . Is there an adhesive you all would use for this sort of situation? The VCT is an Armstrong product if that matters. Any tips you can give to get a decent result are appreciated.
Thanks for comments.
7echo is offline   Reply With Quote
Old 07-08-2012, 02:05 PM   #2
MarginallyQualified
VCT adhesive
Originally Posted by 7echo View Post
The slab is old and a little uneven and has some stains that may be oily Any tips you can give to get a decent result are appreciated.
OK... Use a glueless vinyl sheet remnant instead.
Old 07-08-2012, 03:23 PM   #3
VCT adhesive
I got the VCT for free and thought I could use it. If it doesn't stand much chance of working I sure don't want to put in the labor.
I can ask the flooring guy to save me a couple of drops on the next job.
Even if it is glueless vinyl what can I use to glue it down, particularly at the entrance? Or maybe just use one of those aluminum threshold strips and screw it down?
Removing Adhesive and Paint from Concrete onthejob Flooring 4 03-29-2012 11:11 AM
Wrong adhesive? Smudgeboss Flooring 0 12-30-2011 07:21 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
