VAT Floor Tiles? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 12:48 PM   #16
Mold!! Let's kill it!
Rewards Points: 2,012
Intact asbestos poses no particular danger. Poor removal techniques are the danger. I've removed this stuff. Leave it alone and it will be fine. Coating it with something will likely cause you bigger problems, such as what happens if your coating loosens the stuff. Or if the coating does not adhere or softens the tile. Then you will have an asbestos problem. Don't scrape it, grind it or drill it and it will not become an airborne hazard. Asbestos contained in tiles is embedded in a heavy matrix of asphalt, rubber and vinyl and does not readily become airborne unless you do something that breaks up the matrix.
Old 04-01-2013, 01:41 PM   #17
Floor Installer
sam floor's Avatar
Rewards Points: 154
Originally Posted by RCGA View Post
Well as of right now I plan on using concrete sealer and then an underlayment on both the room with the tiles and the room with just the mastic left.
The biggest problem is that the more I read online, the more I become neurotic about the whole asbestos thing.
Then quit reading about asbestos on line.
sam floor is offline   Reply With Quote
