Old 06-26-2012, 05:10 AM   #1
Varnishing/waxing on top of existing varnish
Hi all
have discovered a pretty good solid floor underneath the front room carpet in the new house. It would appear that clear varnish has been used and is in good order. I would like to treat on top with my favourite light oak shade. However out of all the DIY stores I have only been able to find tinned floor wax in this shade. So I am hoping I can put this onto the varnish layer without having to sand down? thanks
Chris S is offline   Reply With Quote
Old 06-26-2012, 07:56 AM   #2
I see no way that's going to happen and last any longer then it takes to walk on it.
If you want it to last the floors going to have to be stripped, stained and resealed.
Hire a pro to do it and it will come out better and faster then a DIY job.
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
How to tap into an existing outlet to add a new one? jimhokie Electrical 10 01-17-2011 02:04 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 08:54 PM
Marine Varnish?? Geaux4Tigers Painting 7 11-15-2010 10:13 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
