Old 10-24-2006, 04:10 PM   #1
Question
Varathane Floor Refinishing system
Has anyone used the varathane renewal wood floor restoring system? I just bought a home with wood floors that are in good condition except for the topcoat which has a few scratches and appears to have polyurethane thats worn down in spots.
It seems too good to be true...any feedback would be appreciated.
femmebot2277 is offline   Reply With Quote
Old 10-24-2006, 04:40 PM   #2
Master Craftsman
Big Dave's Avatar
I've heard a few bad stories about the Varathane products and I would advise not using it. If it's just worn down in a few spots and not down to bare wood I would call a floor finishing professional and have them take a look. More than likely it just needs a new coat of poly. The biggest problem is that you don't know if it is water base or oil base and they are not interchangeable. A flooring professional will be able to put on a new coat and keep from any major problems from occuring.
Just my opinion, Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 10-25-2006, 09:42 AM   #3
Thanks for the info Dave. You're the first person thats even heard of the product so far, so I don't think I'll be using it.
Old 06-22-2007, 08:39 PM   #4
I used the kit yesterday in a small bedroom and the results were amazing. It made the floor shine like it had been sanded and coated (which I did to a larger bedroom a few years back). As long as your floor is in reasonably good shape, this product is for real!
tnormfrank is offline   Reply With Quote
Old 06-29-2007, 07:36 PM   #5
tnormfrank:
when you put the diamond hard finish on, was it milky white? my husband and i are putting it on now and it's all milky white. will it dry clear? we're worried!!!
kristie
keab is offline   Reply With Quote
Old 06-29-2007, 07:45 PM   #6
It was milky white for the first 30-45 minutes but turns clear as it dries. I used a paint roller to apply the finish rather than the applicator.
Old 06-29-2007, 07:48 PM   #7
THANK YOU SO MUCH!! My husband says, "I wish I would have known that before I started freaking out!" We were worried we were going to have to rent a sander and redo the whole entire floor!
Old 03-23-2008, 08:10 PM   #8
Hi all, does anyone knows where to buy this kit in Toronto? Thanks
hank2000cn is offline   Reply With Quote
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
