Vapor Barrier Under Laminate Over Crawlspace? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 12:24 PM   #1
Rewards Points: 4,792
Vapor barrier under laminate over crawlspace?
Heavy (12 mm) laminate with pad attached, going over plywood subfloor on ground floor, over a crawlspace. Thoughts on putting down a vapor barrier first? Optional or mandatory?
jeffnc is offline   Reply With Quote
Old 02-28-2013, 04:40 PM   #2
Rewards Points: 13,300
Is there a vaper barrier on the ground in the crawl space?
Old 02-28-2013, 04:45 PM   #3
Can't check now - answer both ways :-)
Old 02-28-2013, 04:59 PM   #4
Ony time I'd use a vaper barrier is over a slab or below grade.
But it is really important to the whole house to have a vaper barrier on the ground!.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
