Old 01-13-2012, 06:05 PM   #1
vapor barrier under foam board basement?
going to be installing laminate in my basement for flooring.
plan on putting 1" foam board on the floor, then 5/8 plywood ontop of that. then tapcon screws into the cement.( also doing 1.5" foam on the walls )
should i bother installing a 6mill vapor barrier plastic under the foam board? or does the foam count enough for it?
also, should i follow the 6mill vapor barrier up the walls as well?
alecmcmahon is offline   Reply With Quote
Old 01-14-2012, 03:17 PM   #2
Moderator
Fig. #2: http://www.buildingscience.com/docum...ms?full_view=1
Photo 3: http://www.buildingscience.com/docum...g-your-basment
If you have an interior drainage, fig. 15: http://www.buildingscience.com/docum...lation-systems
Gary
Clothes taking longer to dry?
Best adheasive for foam board to concrete BlueBSH Building & Construction 1 08-05-2011 04:06 PM
Adding foam board insulation & plywood to underside of roof sheslostcontrol Insulation 1 05-04-2011 08:08 PM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
Best Foam for Basement Walls? heybrady Remodeling 5 08-19-2008 11:31 AM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
