-   -   vapor barrier under foam board basement? (http://www.diychatroom.com/f5/vapor-barrier-under-foam-board-basement-129846/)
alecmcmahon 01-13-2012 05:05 PM
going to be installing laminate in my basement for flooring.
plan on putting 1" foam board on the floor, then 5/8 plywood ontop of that. then tapcon screws into the cement.( also doing 1.5" foam on the walls )
should i bother installing a 6mill vapor barrier plastic under the foam board? or does the foam count enough for it?
also, should i follow the 6mill vapor barrier up the walls as well?
Gary in WA 01-14-2012 02:17 PM
Fig. #2: http://www.buildingscience.com/docum...ms?full_view=1
Photo 3: http://www.buildingscience.com/docum...g-your-basment
If you have an interior drainage, fig. 15: http://www.buildingscience.com/docum...lation-systems
Gary
