Old 08-22-2012, 01:54 PM   #1
Using an underlayment in addition to a pre-attached pad on laminate
Hello, We're getting ready to install about 500 sq ft of laminate in our living room and kitchen. The flooring we selected is Allen and Roth (Lowe's). It's 10mm and has a pre-attached pad on the bottom.
We had also wanted to use QuietWalk as an underlayment to cut down on impact noise as well as hopefully cutting down on some airborne noise from the downstairs neighbor. We live in a 3rd floor condo, with a concrete subfloor.
Will we have any issues with the floor being too soft if we use an underlayment on it? I've read some conflicting things on the internet. Lumber liquidators, for instance, says that you can use both. Most other things i've read say not to. Thanks!
joeburke is offline   Reply With Quote
Old 08-22-2012, 06:05 PM   #2
Pro Flooring Installer
rusty baker's Avatar
If LL says you can do it then I would not.
Seriously, what does the manufacturer say? Have you contacted them?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 08-23-2012, 01:14 PM   #3
If using a laminate with an already attached underlay I would not use the other stuff too. The floor would have too much cushion, and having all of that give could actually make the boards bull apart from each other.
Awoodfloorguy is offline   Reply With Quote
What type of underlayment should I put under laminate floor over hydronic heat? MRSFIX HVAC 0 07-03-2009 09:12 PM
Underlayment under laminate sanramonvalleyfitness Flooring 4 12-31-2008 09:56 PM
Underlayment for laminate wilderstyle Flooring 1 11-02-2008 03:45 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 06:52 PM
