Using Self-leveling Quickrete In Large Space - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 05:42 AM   #1
Using self-leveling quickrete in large space
I have a concrete subfloor in the basement that is uneven. I would estimate maybe an inch or more difference throughout and there are a lot of peaks and valleys. It's about 200 square feet. I want to lay tile but would like to level the floor. Is self-leveling slurry the way to go before starting to tile? Should I split up the room into sections before pouring and how? Is there a better solution? Thanks for the help.
klein is offline   Reply With Quote
Old 07-18-2008, 07:55 AM   #2
Registered User
Termite's Avatar
Look at the Ditra product made by Schluter.
Old 07-18-2008, 08:17 AM   #3
Rewards Points: 324
How does ditra fix a 1 inch variation in flooring? I ask because I have a similary situation except for a 1/2 and was told that ditra wont fix it.
tigerbalm2424 is offline   Reply With Quote
Old 07-18-2008, 08:20 AM   #4
Registered User
Termite's Avatar
Sorry, I stopped typing in my first post and didn't finish my point. Ditra is an uncoupling membrane that goes over the substrate, set in thinset. It would be a good idea for a patched/filled floor such as this.
Self leveling flowable concrete could be poured before placing it to level irregularities in the floor. Klein, just be sure that the mix you buy is intended for higher water content and the thickness (or thin-ness) you intend to pour. It isn't something you can do with regular sack-crete, but there are bagged mixes available. Too much water in regular concrete mix will destroy the strength.
Old 07-18-2008, 08:49 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No
way
DITRA
will follow
that
terrain.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 01:06 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
