Using A Self Leveling Compound Over Radiant Floors Laden With "uneven" Sleeper Boards - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 01:50 PM   #1
Using a self leveling compound over radiant floors laden with "uneven" sleeper boards
My husband and I have a dilemna in the great room of our log cabin that we are building ourselves. We have in-floor radiant heating. The radiant heating tubes were laid in between sleeper boards and covered with a cement mix. We are ready to lay the engineeered hardwood flooring but are faced with a very uneven floor; the sleeper boards are 'higher' than the cement, in "a lot" of places. We are thinking of applying a self-leveling compound over the top. Is this the best solution? We would sincerely appreciate any tips or suggestions anyone may have before we begin. Our great room/dining room/kitchen is about 900 sq. ft. Thanks!
mkk is offline   Reply With Quote
Old 11-04-2011, 02:11 PM   #2
I'm not a flooring expert by any means. I suspect that the sleepers are there as nailing support for an anticipated underlay below your finished flooring selection. You didn't indicate what the spacing of the sleepers is which would make further comment more useful. I wouldn't bother adding cementitious material if the tops of the sleepers are level one to the next and your underlay can span the distance. Might want to pay some attention to nail length of the engineered hardwood if its to be nailed down so that a "miss" doesn't puncture the encased tubing.
Marvel is offline   Reply With Quote
Laminate Floors over radiant heat in concrete slab richnsht Flooring 8 05-23-2009 12:16 PM
floor leveling compound geraldS Flooring 4 03-01-2009 08:20 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 11:11 AM
radiant heat in floors What have I done HVAC 2 11-12-2007 10:59 PM
