Using Sand To Fill Low Spots - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 07:54 PM   #1
Rewards Points: 85
I will be tiling a bathroom floor. The 3/4" plywood sub-floor I will be working on has a few low spots in it. Now, I've used floor leveling compounds before, but an old contractor friend of mine said I can just use some sand to fill the low spots before laying my cement backerboard down. Has anyone ever heard of this, or is it a bad idea? Thanks!
Chris Sweeney is offline   Reply With Quote
Old 02-21-2013, 08:01 PM   #2
Rewards Points: 13,714
So you want to lay down a non compactable material that's sure to flex?
How low are these low spots?
What's there now for a subfloor?
Old 02-21-2013, 08:08 PM   #3
Rewards Points: 85
The low spot I'm concerned with is basically a 1/4" valley over the span of about 3 feet. Subfloor is 3/4" plywood.
If I can't use sand, I'll just go back to using floor leveling compound; I just wanted to see if anyone else has ever used sand for this purpose, since it sounds so much simpler. I thought it probably sounded too good to be true though.
Old 02-21-2013, 08:34 PM   #4
I would install the 1/4 tile board in a bed of thinset, use non gypsom floor leveler to fix that low spot then set the tile.
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 04:30 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 01:01 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
