-   -   Using Sand To Fill Low Spots (http://www.diychatroom.com/f5/using-sand-fill-low-spots-172615/)
Chris Sweeney 02-21-2013 07:54 PM
I will be tiling a bathroom floor. The 3/4" plywood sub-floor I will be working on has a few low spots in it. Now, I've used floor leveling compounds before, but an old contractor friend of mine said I can just use some sand to fill the low spots before laying my cement backerboard down. Has anyone ever heard of this, or is it a bad idea? Thanks!
joecaption 02-21-2013 08:01 PM
So you want to lay down a non compactable material that's sure to flex?
How low are these low spots?
What's there now for a subfloor?
Chris Sweeney 02-21-2013 08:08 PM
The low spot I'm concerned with is basically a 1/4" valley over the span of about 3 feet. Subfloor is 3/4" plywood.
If I can't use sand, I'll just go back to using floor leveling compound; I just wanted to see if anyone else has ever used sand for this purpose, since it sounds so much simpler. I thought it probably sounded too good to be true though.
joecaption 02-21-2013 08:34 PM
I would install the 1/4 tile board in a bed of thinset, use non gypsom floor leveler to fix that low spot then set the tile.
