Using Pergo On Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 09-19-2005, 07:38 AM   #1
Using Pergo on Stairs
I have a carpeted staircase that is sorely in need of a facelift. I don't believe the floor underneath is in good shape. I was thinking about using Pergo/laminate flooring. I've used this before (in the kitchen) and I was happy with the results.
I know they sell a stair nose molding, which is used at the lip of the stair, and a quarter round used where the step meets the riser. However, I know that laminate flooring is supposed to float, so I'm worried that it might not be a good solution for the stairs.
If anyone has any experience or thoughts about putting laminated flooring over stairs, I'd appreciate your insights. Also, if you know where I can get a step-by-step DIY guide for the stair installation that would be helpful, too. Thank you.
NewYorker is offline   Reply With Quote
Old 09-19-2005, 08:44 AM   #2
Contractor
Google 'pergo on stairs', at the top will be the pergo site with all of the info. There is too much info to transfer here. Have any questions not answered there, come on back. I've done all kinds of stairs.
Teetorbilt is offline   Reply With Quote
Old 09-19-2005, 09:29 AM   #3
I got the instructions. They are good and have a few illustrations. On the stair application, the flooring gets adhesived down without any underlay. This makes sense, and it looks like something I can do. Thank you.
Old 09-19-2005, 03:45 PM   #4
Floorwizard's Avatar
Wilsonart has the "one step stairtreads"
worth looking into.
www.wilsonart.com
Floorwizard is offline   Reply With Quote
Pergo Presto diyfred Flooring 14 10-07-2010 03:52 PM
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 10:51 PM
