Old 10-21-2006, 06:43 PM   #1
Using a jack to raise joists
I need to sister some joists in the basement. I have a 20-ton Husky bottle jack that can do the job. Most people say to only raise the joist 1/4 inch and leave it that way for a day before raising it again. Will the bottle jack be able to maintain that for the day or do I need to get another post to hold it in place?
drhowarddrfine is offline   Reply With Quote
Old 10-22-2006, 12:38 AM   #2
renovations
If the jack doesn't creep (has good seals) it will stay where you put it. But no harm in putting a post under it too. Are you just jacking the centre of the joists trying to take some sag out? Or are you lifting things up above as well?
Bonus is offline   Reply With Quote
Old 10-22-2006, 09:42 AM   #3
That's what I thought but I read an article that gave the impression the bottle jack was good enough. Thanks.
The stupid builders cut about 1/3 of the joist out for a vent. The joist now has a bow in it about 1/3 in from the plate on the foundation. So I guess I have to lift up around the middle.
Phone/Fax Wall Jack cmgith Electrical 5 04-19-2009 12:21 AM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
Need to Jack up part of my house.... harleysilo Remodeling 24 10-01-2006 09:05 AM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
