Using Hardie Panel Siding As Finish Flooring - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 07:47 PM   #16
Rewards Points: 13,732
http://www.bing.com/shopping/search?...RM=HURE#x0y943
Any box store has them.
Old 08-10-2013, 02:34 PM   #17
Bill Kearney
Rewards Points: 1,174
Having dealt with a number of government analysts in my time I wouldn't put much stock in that. We're all experts at something, but unless you deal with analyzing these materials and interacting with these vendors directly I wouldn't go assuming that means anything.
The world is full of examples of half-assed implementations. Bragging rights for stupidity isn't the same as innovating outside the box.
Why bother with this idea? Because you've already got a ton of this stuff on-hand and are trying to be frugal? That's a laudable goal, but you'd probably better off donating it to SecondChance or ReStore and taking a tax deduction on it.
But if you're actually going to go out and buy some then why not just buy the right kind of product instead?
As for surfaces on a deck to resist burning, what is it you're putting up there that would even come CLOSE to radiating enough heat downward to present a problem? If anything just get one of those mats designed for placement under grills.
One side note, any time you want to put materials on a deck you'd do well to take their weight into consideration. Your deck may not be built to handle the greater weight non-standard materials might present.
wkearney99 is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Hardie ColorPlus Lap Siding Ezekiel Building & Construction 5 10-23-2008 07:17 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Best caulk for Hardie Plank siding? Solar Dave Building & Construction 7 09-28-2008 08:02 PM
