Using GP Dens Shield Over Vinyl Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 07:54 AM   #1
Rewards Points: 12
Using GP Dens shield over vinyl floor
Hello,
I am a newbie to the list....so here goes!!
I am installing a ceramic tile floor in our entry way this weekend, and have a question of how to attach the GP Dens shield backer board. I am going over 3/4" plywood,covered by luan and vinyl flooring. I am using 1/4" Dens shield to achieve the required 1 1/4 " thickness. Do I thin set the backer down and screw it, or just screw it down and forget the glue?
Norm
norm58 is offline   Reply With Quote
Old 08-27-2008, 06:30 PM   #2
Rewards Points: 1,644
Norm,
If you go to the GP site:
http://www.gp.com/build/DocumentView...elementid=3112
they provide instructions.
Nothing there about your application. Why not telephone them and ask?:
Gypsum Products Technical Hotline
1-800-225-6119 (Monday - Friday 8AM - 5PM ET)
General Inquiries
1-800 BUILD GP
(800-284-5347)
Hours: 8AM-5PM ET, Mon - Fri (except holidays)
bob22 is offline   Reply With Quote
Old 08-27-2008, 11:01 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
ALL tile backer boards require thinset mortar under them. You should also removed the vinyl AND the 1/4" underlayment. Whoever told you 1 1/4" is required and that 1/4" underlayment counts is wrong.
Jaz
Old 08-28-2008, 07:38 AM   #4
Rewards Points: 12
Hello,
I called GP this A.M. They also said to not use the Dens Shield backer over vinyl. Looks like I will be pulling up the vinyl and luan. Do I then use 1/2" backer over the 3/4" sub floor?
Old 08-28-2008, 11:58 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 412
If the subfloor system, (framing and if the 3/4" ply is in good condition), all you need is 1/4" backer. Use thicker CBU if you need the height. The backer adds little or nothing in strength.
Have you checked the deflection factor of your joists yet? How old is the house? Check and report back; the type and size of your joists, grade and species would be helpful, the unsupported span, and spacing from one joists to the next.
Jaz
Old 08-28-2008, 12:09 PM   #6
Rewards Points: 12
I am at work now (shame on me), but the house is 15 years old, the joist are 16' OC, I think they are Douglas Fir?? I have room to put in 1/2" without having to cut off any doors etc., plus this would bring the floor up to the adjacent room height. Thanks for all the help!!
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Discoloring Vinyl Floor - what causes? jombres Flooring 8 01-23-2008 11:33 AM
big mess on vinyl floor installation thecanadian Flooring 1 03-19-2006 07:28 PM
