Using On Demand Water For A Heated Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 04:06 PM   #1
using on demand water for a heated tile floor
We have a room in our basement that we want to remove the carpet and install tile. We are planning on installing heating elements under the tile, either electric or hot water. We are also thinking about installing an on-demand water heater. Can a tankless hot water heater be used as the source of hot water for the heated tile floor?
Al Hibbard is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Replacing Tile Floor in Shower banglenot Flooring 9 05-23-2011 10:05 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Radiant floor heat under 3x8 feet wide strip of tile - how to build up rest of floor? lazzlazz Flooring 2 03-31-2010 06:52 AM
