Using Concrete Slab As Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 04:50 PM   #1
Using concrete slab as flooring
I have terrible allergies and we have dogs as well. We have thought about pulling the carpet up in our bedroom and using the concrete slab as the flooring with some throw rugs. My question is whether this is safe to do as is or do I need to treat the concrete before hand. Thanks for any help.
noleeo is offline   Reply With Quote
Old 06-10-2012, 05:49 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
The concrete should be fine. It can be stained to add some character. Just be aware, bare concrete can be bad for feet, legs and back over time. It also will be cold in the winter.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-10-2012, 09:09 PM   #3
Rewards Points: 240
properly stained, good condition, concrete can look AWESOME !
Fix'n it is offline   Reply With Quote
Old 06-11-2012, 10:05 AM   #4
Rewards Points: 3,818
Polished and sealed look's good too.
Canarywood1 is offline   Reply With Quote
Old 06-11-2012, 01:07 PM   #5
I recently pulled all carpet in our bedrooms, more recently in our dining room and in our basement. My wife and kids all suffer from allergies and we also have 3 big, very active dogs. Never ever will
I have carpet in a house.
On the 1st floor I replaced the carpet with laminate wood flooring. paid $17.00 per 25 sqf. plus some high quality underlayment ~$50.00 per 100 sqf. Well worth it.
Along your requirements, I am in the process of adding the same laminate flooring from
bedrooms to my basement on my concrete slab using delta-fl and cheap foam underlayment.
Looks and feels great and isn't terribly expensive. Much less than tile or carpet. Dogs loves it. See pictures.
http://www.cosella-dorken.com/bvf-ca...roducts/fl.php
JP
Using concrete slab as flooring-image-3901465326.jpg   Using concrete slab as flooring-image-2272324895.jpg
the1german is offline   Reply With Quote
Old 06-11-2012, 10:15 PM   #6
I would polish or stain the concrete. It can look really nice. You can even grind in tile patterns, if you wanted. Search youtube for concrete acid staining and you can find a lot of how to info.
RhodesHardwood is offline   Reply With Quote
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 06:16 AM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
