Using Composite Boards As Shims - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 05:16 PM   #1
Using Composite Boards as shims
I am considering cutting long, 8 foot shims to correct a joist leveling problem (1 inch over 8 feet).
I thought about using composite boards for this. It seems they would be better than wood because of low compression and change due to temp and humidity. Any thoughts/experiences?
Thanks in Advance,
Deadskins is offline   Reply With Quote
Old 01-18-2012, 07:03 PM   #2
Civil Engineer
Rewards Points: 4,522
Shims are generally so thin that changes in dimension due to humidity changes are not an issue. If you need really fat shims, they aren't shims, they are stock lumber. As for the composite boards, a lot of them are made from a combination of plastic and sawdust, and they are not particularly strong or stiff, less so than standard lumber in most cases. For your application, I would use a strong hardwood shim such as oak, maple or ash. If you cannot get that type of lumber, you could use hard pine. Sounds like you will need to rip it on the tablesaw, maybe even use a tapering jig.
Old 01-18-2012, 07:11 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Oh not this again.
titanoman is offline   Reply With Quote
Old 01-18-2012, 08:05 PM   #4
Rewards Points: 2,202
It all good. To cut the "shims" do you have a table saw? or a circular saw?
mae-ling is offline   Reply With Quote
Old 01-18-2012, 09:28 PM   #5
Rewards Points: 506
I hereby nominate tapering jigs as a Sticky topic.
jlmran is offline   Reply With Quote
Old 01-18-2012, 09:33 PM   #6
Rewards Points: 12,868
And why not sister joist to level it. Pull two strings across the joist and set them to be even with the strings.
Better yet figure out what there not level and fix that.
Old 01-18-2012, 09:36 PM   #7
Yes, I have. Good table saw.
As for sistering, the 2x10 joists are already sistered, just not level.
Good idea about using oak or another hard wood.
Composite deck with wood railings? Or ditch the composite and go all wood? CoconutPete Building & Construction 5 07-29-2010 01:30 PM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 12:09 PM
composite deck boards rcassidy Carpentry 7 04-24-2009 09:24 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
I Am Confused About Composite Dek Boards boots Carpentry 1 03-11-2007 02:02 PM
