Old 01-30-2008, 10:04 PM   #1
DIY Expert in Training!
Using Ardex Feather finish-nervous!
In case it's not obvious by my simply questions this is my first big project. I am pulling up tiles this weekend and using the Ardex Feather finish to encapsulate the floor (asbestos). I am nervous about applying this product. I want to make sure I end up with a nice smooth floor that I can lay tile on in a few weeks.
Any advice, tips, and tricks would be greatly appreciated!
Thanks!
gone_fishing is offline   Reply With Quote
Old 01-31-2008, 04:12 AM   #2
Mix it smooth and spread it evenly.
Ardex is the best feather finish on the market
mike costello is offline   Reply With Quote
Old 01-31-2008, 10:56 AM   #3
Tileguy
Bud Cline's Avatar
FWIW:
These products are not intended to be a wear-surface so once they are installed they should be covered with the final product before too long or traffic should be curtailed until the final product can be installed.
"...Ardex is the best feather finish on the market"
That's opinion not necessarily fact.......
Mapei Plani Patch is a comparable product and a little less costly. There are many other comparable products available also.
Old 01-31-2008, 11:15 AM   #4
Bud, I will be working in the room after this finish in down for 2-3 weeks before I can tile. Need to frame a wall, pack out my one wall and dry wall. Perhaps I should do some other things first so I can tile quicker.
Old 01-31-2008, 01:08 PM   #5
Tileguy
Bud Cline's Avatar
The traffic patterns will turn to sand with a couple of weeks of foot traffic on them. You could cover the area with rosin paper or craft paper.
Or you could wait until other tasks have subsided to install the skim coat.
Old 01-31-2008, 02:06 PM   #6
It won't be high traffic. Just me so I will risk it...I'll just put down down tarps and maybe ply wood. I'll try to hurry up so I can get the flooring down quicker.
Old 03-13-2008, 12:59 PM   #7
Maybe this post is too late, but might help someone in the future.
Ardex Feather Finish is not the product for this job. It is designed to do what is says on the tin (or bag/bucket). It is for skimming joints etc. where minimum thickness is required - hence feather finish.
You need a screed. Either water based or latex based self levelling compound. 1/8". For the water based one use a primer, usually neoprene and you should get it where you get the material.
Mix with a whisk and lay immediately. If a proper job is to be done use a spiked roller to finish whilst still wet.
taranis is offline   Reply With Quote
Old 03-30-2008, 07:34 PM   #8
M D Tile
We generally use ardex for feather finish prior to vinyl and/or vct installations and have had great success ove both wood and concrete, however, most producers of thinsets and other cementuous based adhesives will also produce both modified and un-modified floor levelers that offer greater support which can be helpful when installing ceramic tiles. Priming the floor prior to leveling is a procedure that is often skipped by
do-it-yourselfers and often resulting in seperation and/or flaking of the levelers from the substrate. It is not generally advised to pour levelers over 1/4" in single pours. additional pours with adequate curing times between each pour may be necesary to acheive overall leveling of the area and may require addition priming between pours. My recomendation is to take the additional time and spend the additional money to do the job right the first time and prevent some possibilities of costly damages down the road. The manufacturers product specs and procedures may differ from another so be sure to read the directions. Stay away from store name products as they generally do not perform as well as the brand name products.
MD_Tile is offline   Reply With Quote
Old 03-31-2008, 03:45 AM   #9
agreed
Levelquik or Ardex FeatherFinish? rsilvergun Flooring 4 02-01-2011 06:58 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
Stair Finish - wood or paint TRM Painting 3 01-16-2008 01:33 PM
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 03:26 PM
cabinet maker's finish jim_k Painting 5 08-03-2007 02:37 PM
