To Use Red Rosin Paper Or Not With Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 07:23 PM   #1
Rewards Points: 37
Lightbulb
To use red rosin paper or not with hardwood floors
I'm installing 5/16 Brazilian Walnut above a finished heated/air conditioned basement. I have installed a new plywood underlayment and am now ready to install the floors. The floors have been acclimated to the new room for 3 weeks. I have read conflicting opinions over whether to use felt paper, red rosin paper, or nothing. Would the red rosin paper be required or useful since the floor is over a finished basement where I am not worried about moisture? Are there other reasons to use it? I made sure to secure the subfloor and underlayment with screws to prevent squeaking.
interplexr is offline   Reply With Quote
Old 02-27-2009, 09:00 PM   #2
Remodeling Contractor
not worrying about moisture in a basement, means that you do not understand basements. There is moisture to contend with. What did you place under your underlayment? Anyway over this you should use felt paper since you may not have dealt with the moisture properly. Other wise I would use rosin paper. Unless your concrete floor in the basement is over 25 years it will still be releasing moisture. Without a capillary break, this transfer will continue due to a pressure difference above and below the slab.
Old 02-28-2009, 06:18 AM   #3
Rewards Points: 37
I don't think I explained what I was doing very well. I'm not installing the floor in the basement. The floor is above the basement on the first floor. The house is over 25 years.
Old 02-28-2009, 07:20 AM   #4
Definitely use rosin paper, unless the floor is glued down. The purpose of the paper is to isolate the subfloor and top floor from contact so that expansion/contraction will not cause squeaking. Felt used to be the standard, but rosin is a bit slipprier.
Old 02-28-2009, 07:49 AM   #5
yes.. rosin for this installation
Old 02-28-2009, 07:51 AM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
I agree!
Old 03-12-2009, 11:36 AM   #7
Felt paper all the way.
canuck88 is offline   Reply With Quote
Tags
basement , felt paper , floor , hardwood , rosin paper
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 12:20 PM
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 06:05 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 06:59 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
