Use Cork Tiles Under Basement Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-28-2004, 11:40 AM   #1
Use cork tiles under basement carpet
I am currently finishing my basement. My father in law has told my wife about placing cork tile on the cement floor under the carpet and pading. to help with insulation and so forth. I have never hear of anyone doing this and I was just trying to get some thoughts on doing it. The wife keeps asking me when are we getting the cork tiles and I keep saying I want ot ask someone about it first. Any input would be great.
Thanks in advance,
Sal
Tech7 is offline   Reply With Quote
Old 12-28-2004, 01:33 PM   #2
Floorwizard's Avatar
if you lay the cork flooring, there will be no way to lay the pad or stretch it in properly.
if you glue the pad or the carpet to the cork, it may come loose in time.
why not lay cork tiles, and then a couple big area rugs?
Floorwizard is offline   Reply With Quote
Old 03-20-2011, 08:15 PM   #3
I have heard of it, but not too often, If you do that you would need to install it like a pad, and then you can overlay a thinner pad on top. But you could also just get a good padding and that would do much the same.
IceT is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Padding for Basement Kyle Flooring 2 10-14-2006 09:05 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
