-   -   to use backerboard or not? ceramic tile (http://www.diychatroom.com/f5/use-backerboard-not-ceramic-tile-56458/)
rebelbull 11-02-2009 03:28 PM
im going to do my house in ceramic tile right now i got the hardwood floor down
do i have to use the hardibacker? it will add a good bit to the price
but is it really nesseciary
my house is on pier and beam
thanks very much
jaros bros. 11-02-2009 05:53 PM
Tile needs a substrate. I would recommend Ditra.
JazMan 11-02-2009 08:07 PM
Hi bull,
You think backer board is expensive? :no: OH boy, maybe you want carpeting instead? :whistling2:
You can NOT install any tile on hardwood. You can NOT even install backer board over hardwood. You need to removed the hardwood, then evaluate and probably add a plywood underlayment then install the backer or Ditra, and then the tiles. :yes:
The pier and beam construction common on the left coast can also be problematic at times, but most of the time it can be done if the subfloor is thick enough.
Jaz
