Use 12" Or 18" Tiles In 30" Area? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 04:26 PM   #1
GBunny
Rewards Points: 71
Use 12" or 18" tiles in 30" area?
I have an ensuite washroom that is reverse "L" shaped. The door is on the right, the sink on the left (just inside door). The toilet is in a 60" x 30" recessed space.
We are tiling on top of tiles - is this ok? The plywood underneath looks like it's been wet at some point. This is a very small area - in total only 36 s.f. I think.
The contractor is advising centring an 18" tile in the doorway and put 6" pieces on either side where the toilet is.
I think it would look better if he uses 12" tiles and put one 6" piece.
Could I have some advice please? I thought you were only supposed to use large tiles for large areas? Isn't it better to minimize the number of cuts also?
GBunny is offline   Reply With Quote
Old 04-19-2011, 04:35 PM   #2
DIY'er
DIYadam's Avatar
I don't know, covering up tile that is sitting ontop of a once wet subfloor doesn't sit well with me.
I would take it all up and do the tile on a fresh subfloor, you'll feel like a million bucks.
DIYadam is offline   Reply With Quote
Old 04-19-2011, 04:50 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
adam has a good point. If you know it was wet, do you know if it is rotted.
the reason for the 2 cuts is because it typically looks better to have symmetry. If you consider that, you would end up with 2 3" cuts, one being on either side. Small cuts show differences in the width more than a larger piece.
Ultimately, it is a matter of aesthetics though and since this is your house, you can ignore the guy that has been doing this for a lot of years and has had people tell him what looked good and what didn't or you can make your own decision on how you want it installed.
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
