Old 03-08-2012, 07:23 AM   #1
urrghhh vinyl stick tiles
i took on a side job laying subfloor down and then laying peel and stick cause i thought it'd be a breeze and some quick cash. im learning now what a nightmare! i layed 400sqft of the peel and stick and i left it with 80-90 degree heat going so the glue would be nice and soft and just melt down. wrong! i popped in to see how the floor looks and F****K! about a 1/4 of them are peeling up on them a bit with zero traffic on them. can i add some contact cement to the nonsticking tiles? or another adhesive? i did a search on here and i see lots of "stir clear of peel and stick" but no answers! im not starting over and putting something else down at this point! can someone give a suggestion?
princelake is offline   Reply With Quote
Old 03-08-2012, 08:06 AM   #2
the Musigician
DangerMouse's Avatar
Peeling up as in curling edges? Can you shoot us some photos?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-08-2012, 08:14 AM   #3
Pro Flooring Installer
rusty baker's Avatar
You can use clear thin spread adhesive, same stuff used on commercial tile. But you will need to take up the tiles that didn't stick, because this adhesive must dry to the touch before any tile is installed on it.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 03-08-2012, 08:17 AM   #4
Super Moderator
I don't have an answer---just the likely causes----
did you use Luan ply? that product often contains resins the prevent proper bonding--
Did you paint on a latex bond enhancer before you started? Sticky tape needs a smooth ,dust free surface---bond enhancer will provide that---(even helps seal in the resins in Luan ply)
Old 03-08-2012, 08:22 AM   #5
I have found this problem in the past and have found that it takes a couple of days for the ones not sticking to finally adhere....
Strange but it seems to be the answer to wait a couple of days and then use a vinyl tile adhesive on the ones not sticking.
I hope you charged enough to keep track of it for about a week. Stupid, but it seems the current bunch of peel and stick doesn't adhere as well as in the past. i remember it used to stick to anything.....
framer52 is offline   Reply With Quote
Old 03-08-2012, 08:25 PM   #6
i went to the flooring place where i got the tile and they told me to use this multiply purpose glue of some sort and i tried it and it was not working so i called a flooring installer thats been in the business almost 40years and was like what the heck just buy all purpose vinyl glue and it'll hold so im gonna do that this weekend. fingers crossed!
Old 03-08-2012, 08:37 PM   #7
Didn't I tell you already to do that??
Old 03-08-2012, 08:45 PM   #8
Tileguy
JazMan's Avatar
Self stick adhesive is pressure sensitive and so needs traffic to bond properly. If the tiles were sticky and the floor smooth and dust-free, you need NO more adhesive. We still don't know what you set the tile over. 80-90 degrees? What were you thinking?
You do NOT use all purpose for vinyl tile. All purpose is for sheet vinyl. Spread it, lay it, roll the air out of it. Done. You do not wanna lay tile like that. Could take you a few weeks to do.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-08-2012, 08:47 PM   #9
while that is true, i was referring to some not all of the floor not sticking.
I agree about the traffic, except I have had a similar problem last month and found a work around as we are all familiar with.
By the way, the only time I use them are on rental property and I detest using them, but money is money.
Old 03-09-2012, 09:15 PM   #10
yes yes you did tell me framer52. this weekend i'll be fixing it up so we'll see how she goes
Old 03-09-2012, 09:18 PM   #11
Super Moderator
So what did you use as an underlayment?
Old 03-09-2012, 09:31 PM   #12
One of the many reasons if someone wants me to install peel and stick I say no thank you.
Mike has asked you many times what the under laymant was and no reply.
For it to have a chance in heck to stay stuck it needed to be 1/4 underlayment rated plywood not louon.
JetSwet (03-09-2012)
Old 03-09-2012, 09:53 PM   #13
3/8" ply good one side
Old 03-09-2012, 10:10 PM   #14
JetSwet's Avatar
Sanded or non sanded?
JetSwet is offline   Reply With Quote
Old 03-10-2012, 04:20 PM   #15
nonsanded
Vinyl floor tiles on vinyl floor Project423 Flooring 2 02-27-2012 02:04 PM
Help with vinyl tiles in bathroom BethM Flooring 4 01-29-2012 02:50 PM
Trying to install self stick vinyl tile on ceiling but it doesn't stick buggy Tiling, ceramics, marble 2 01-27-2012 06:50 PM
Will mortar stick to vinyl tile adhesive on a cement basement floor? samik Building & Construction 6 10-16-2011 04:47 PM
self stick vinyl tiles over existing linoleum? cswanson69 Flooring 1 10-26-2010 01:16 PM
