Urethane Too Thick - Flooring - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 09:41 PM   #1
Urethane too thick
I am in the process of finishing a hardwood floor. I applied the first coat of polyurethane today and think it may have been too thick. I used a lambs wool applicator. I did some small areas with a 4" brush and they seem to be perfect (they already look like the satin finish after 5 hrs) but the part I did with the lambs wool still looks wet even after 8 hrs. Any suggestions on how to fix this issue?
yogib is offline   Reply With Quote
Old 05-03-2009, 08:08 AM   #2
Typically the first coat thould be thinned slightly, but what you have is now what you must work with. Does it feel wet?? You need to sand between coats, so it needs to be dry enough to sand(screen). For oil based, it is not unusual to wait 24 hrs between coats. Water based, about 4-6 hrs after the first coat, subsequent coats usually dry more quickly.
Window Replacement and siding over T-111 and thick felt board Badger Hill Building & Construction 4 05-04-2009 09:27 PM
how thick can I "skim coat"? raz Painting 6 01-11-2009 09:01 PM
Way to fix a nick in hardwood floor urethane? curls00 Flooring 3 07-31-2007 04:43 PM
Thick Paint to help amateur Drywall Job fburke Painting 6 07-29-2007 10:31 PM
Will a rototiller be able to till thick mulch into my soil? joeyboy Landscaping & Lawn Care 7 06-30-2007 06:54 PM
