Unstable Subfloor For Tiling - Flooring - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 10:40 PM   #1
hohadcr's Avatar
Rewards Points: 338
Unhappy
unstable subfloor for tiling
Hi, everyone, thanks for reading
We put down new subfloor (3/4" chipboard, glued and screwed to slats of 13" distance) on old subfloor. We are planning to use Easyboard as sublayer for tiling (dont ask how we still have Easyboard). Tiling will be for the kitchen, 15'X15', hall way5'X30 and two baths, using normal inexpensive tiles.
Now we put the Easyboard down following the instruction, we reallized that our floor may not be stable enough for tiling:
If our friend of maybe 260lbs jumps a bit on the floor, we can see vertical movement almost everywhere about maybe at least 1/4", anyhow, we see the floor moving under his jump/hard steps.
in this kind of situation, should we be concerned about tiling on such floor? Should we totally abort the idea? (which will be hell for the "designer" of the project.)
thanks...
hohadcr is offline   Reply With Quote
Old 08-26-2010, 06:37 PM   #2
floor_whore
Send a message via Yahoo to Aaroncarpet
Mud Pack
rather than using a manufactured underlayment, you should construct a mud pack underlayment with chicken wire and dry mud.....it will absorb over the joists....it is like cement but different...you may have to go thicker and adjust your doors and transitions
Aaroncarpet is offline   Reply With Quote
Old 08-27-2010, 12:10 AM   #3
do you have access to the floor joist from below?
gjjr2001 is offline   Reply With Quote
Unstable Structural Wall joe_cole5000 Building & Construction 8 02-01-2010 08:33 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
